Hi Nikhat,
Thanks for your response! Yes, you're right, our goal is to replace the polyethylene (PE) lining used in paperboard takeout containers. We've seen many of the same scalability challenges you mentioned. However, we're formulating a coating that can be applied directly onto paperboard using existing coating equipment.
I completely agree that migration testing and regulatory validation are key next steps - we're currently working toward that. And thank you for mentioning Sway, they're doing great work in this space!
The clay-coated + aqueous barrier combination is also interesting; it's great to see multiple solutions emerging that can help the industry move away from PE.
Appreciate you sharing your expertise and resources!
Best regards,
Mayela Fernández
Co-Founder & CEO | Ecoplasticity
Mayela Fernandez
Student
Cal Poly Packaging
San Luis Obispo CA
1
Sent: 10-26-2025 08:11 PM
Subject: Thoughts on Bio-based Packaging??
Hi Mayela,
As I understand, you plan to replace the polyethylene (PE) layer currently used in paperboard takeout containers.
There have been some scalability challenges associated with using seaweed film as a packaging material or laminate. However, it has shown good stability upon contact with food, and the overall migration limits and potential effects on food safety appear to be within acceptable standards. That said, further research is still needed in this area to validate long-term performance and regulatory compliance. There is a company called Sway which is already into seaweed based films, you may check them
Another promising alternative could be clay-coated paper with an aqueous coating. This combination offers the premium print surface of clay-coated paper while providing the food-grade barrier properties of an aqueous coating, making it suitable for cups, bowls, and takeout containers.
Nikhat Sayed
Printing & Packaging Engineer
Irvine CA
(714) 548-4383
