Hi Emilie,
We use '5' based on our supply chain process and the environmental/transportation hazards potentially encountered by our products.
The majority of our products are sourced off-shore, so products are exposed to humidity, shifting (due to being floor-loaded), vibration, etc.
Hope this helps!
Regards,
|  | Oksana Lapierre CPP Senior Packaging Optimization Consultant Canadian Tire Retail 2180 Yonge Street, Toronto, ON M4S 2B9 T 416-480-9780 (ext. 28734) Oksana.Lapierre@cantire.com |
This message, including any attachments, is privileged and may contain confidential information intended only for the person(s) named above. If you are not the intended recipient or have received this message in error, please notify the sender immediately by reply email and permanently delete the original transmission from the sender, including any attachments, without making a copy. Thank you.
Ce message, y compris toutes ses pièces jointes, est confidentiel et peut contenir des renseignements destinés uniquement aux personnes dont le nom est indiqué ci-dessus. Si vous n'êtes pas le destinataire prévu ou si vous avez reçu ce message par erreur, veuillez en aviser l'expéditeur immédiatement, en lui répondant par courriel. Veuillez aussi supprimer définitivement le message original de l'expéditeur, y compris toute pièce jointe, sans faire de copie. Merci.
