This message was posted by a user wishing to remain anonymous
As a manufacture of HFFS equipment there are numerous options for PETG conversion such as Pacur, Amcor and Impac as mentioned, I would consider when using Virgin PETG vs HIPS that you make sure your plugs and plug materials are correct as that will help with down grading your materials. We typically use IR heat with PETG as you get a superior Distibution of material over contact heat. Just make sure you heat both side on the sheet with contact plates.
