Hi Kalpeshkumar,
Thanks for your insights-those are all crucial factors when optimizing film thickness in extrusion! Die gap uniformity and air ring cleanliness, in particular, can have a significant impact on maintaining consistency, especially when running multi-layer structures.
I'm curious-have you found any particular challenges with die leveling when working with different resin formulations? Some formulations can be more sensitive to minor misalignments, leading to gauge variation across the web. Also, regarding cooling rate, have you experimented with varying air ring pressures or chiller settings to fine-tune thickness distribution?
In my experience, even small adjustments in cooling parameters can significantly impact final film properties. Looking forward to hearing your thoughts!
Best regards,
Eric Moe CPP
Sales Engineer
Precision Die Systems
Chippewa Falls WI
(715) 861-5704
Sent: 10-07-2024 12:41 PM
Subject: Overcoming Key Challenges in Slot Coating, Extrusion, and Blown Film Processes
Hi Eric
For Optimizing film thickness in film extrusion, we should look on below points.
# Die Gap uniformity
# Nip to the die centering
# Die level
# Die and air ring cleanliness
# Frost line/Stable bubble/ Center
# Cooling rate
# Resin quality/Types of resin/ Layer ratio/ Formulation
Thanks
KALPESHKUMAR SUTHAR
Layfield canada Ltd
RICHMOND BC
3069995830
