So typically you would also do shipping studies as well as validating any of those parameters in the shipping lane. This would be things like is refrigerated storage needed, does label adhesiveness hold up based on the region and market you are shipping it in.
"However, shipping variables and environment weaken the seal strength." These are parameters that also need to be tested.
"We do random sampling on the line." What type of sampling plans do you use? and also do you do line check parameters, pre and post, to ensure no parameters "fell" out of requirements.
And not split hairs but I would think something other than glass bottles could be used for packaging. I would assume those are quite costly
Sent: 07-17-2024 07:29 AM
Subject: Induction Liner Sealing to Glass Containers
We do random sampling on the line. However, shipping variables and environment weaken the seal strength.
Seth Cramblett CPP
Production Engineering Specialist
Wiley Companies
Coshocton OH
(740) 502-8635
Sent: 07-16-2024 05:57 PM
Are you doing any validation on induction seal parameters?
Sent: 07-11-2024 09:03 AM
Good Morning!
We package fish oil softgels in glass wide mouth packer bottles ranging from 120cc to 400cc (38mm to 53mm closure size). We do get complaints from customers for failed seals. This usually occurs with our 53mm closure size. We currently use the Selig LPM (Universal Liner) to seal our bottles. However, I'll be conducting testing on the Selig LPF (Glass Specific Liner) in the next month. I'll be conducting a vacuum decay experiment on both the LPM and LPF liners. I'll keep you posted on the results.
Seth Cramblett CPP
Wiley Companies
Coshocton OH
(740) 502-8635
