This message was posted by a user wishing to remain anonymous
We're currently discussing the quality of medical device sterile barrier systems, which consist of a rigid tray (e.g., PETG) and coated Tyvek. While the specific combination is intended for cohesive peel, we occasionally encounter areas of what appear to be an adhesive peel or an incomplete sealing. In the specific case the defect appears in the middle of the seal area, why a dye leak test doesn't add information.
I'm looking for advice on:
- Differentiating between adhesive peel and actual defects: What are the key indicators to look for?
- Setting requirements for adhesive peel: What standards or guidelines should we follow to ensure the integrity and reliability of the seal? It seems that it is difficult to avoid discontinuous seals completely for this kind of sterile barrier system, but we would like to specify how much/little is acceptable. Which data do we need to support the decision?
- Common issues: What are the typical problems associated with discontinuities in the seals, and how can they be mitigated?
Any insights or shared experiences would be greatly appreciated!
