Hi Keli,
Polyurethane for this should have a higher hardness of 80 to 90 Shore A, though the height of 25 cm is not that high but a higher density of 40-50 lbs/ft³ density range should be able to protect the 121 lbs product. A foam with a lesser compression will be able to protect the product.
You may go with EPS (Expanded Polystyrene), EPS should also give a good compressive strength, and it can be moulded as per the shape and it will be good for transit. You may have to conduct ECT and BCT.
I hope you considering an ASTM (ASTM D4169, D5276, D3332) standard for testing. An ISTA 1A with ASTM should give you a comprehensive result.
Regards
Nikhat Sayed
Printing & Packaging Engineer
Irvine CA
(714) 548-4383
