All,
I am plannning to change the plastic gallon bottle for 22 chemicals we manufacture, most them are dangerous good. What will be the best standard test to follow for checmical compatibility of material with all?
I have considered using Appendix B to Part 173-Procedure for Testing Chemical Compatibility and Rate of Permeation in Plastic Packaging and Receptacles, if i use the origianl volume, the test can be expensive?
Any suggestions?
Juned Khakhi CPP
Senior Packaging Material
Leica Biosystems
Richmond IL
(316) 516-8048
