  • 1.  48EB as an ECT value?
    Posted 08-21-2026 09:16 AM
    Hello,
    Does anyone have any information regarding this board structure and its correct ECT value? I believe that this is a new offering in the corrugated arena, but that there is a LOT of variation in how it is referenced and what it actually is.
    Thank you for your help with this.
    Dee Brewer CPPL
    Packaging Engineer
    Teasdale Latin Foods
    Carrollton TX
    (281) 685-6445
  • 2.  RE: 48EB as an ECT value?
    Posted 30 days ago
    If they certify it as 48 ECT then that is the lowest it can be they can use multiple board combos to achieve this. Ideally, a 48 ECT BC is the same strength as as 48 ECT EB
    Kyle Yerdon CPP
    Packaging Engineer
    Kettle Cuisine
    Melrose MA
    (813) 283-8025
  • 3.  RE: 48EB as an ECT value?
    Posted 29 days ago
    48EB is 35 / 23 / 33 / 23 / 35. It uses an E flute medium closer to the outer liner and B flute medium closer to the inside liner. It has 0.1875 caliper, so it designs similarly to C flute. My team has been using it for a few years, though we usually default to 51EB instead of 48. Does this help?
    Kelli Schenck, CPPL
    The BoxMaker
    Kent WA
    (650) 477-0648
