SPI tolerances on T and E for standard CT neck finishes were/are +/-.012". Most blow molders can work within that (+/-.010" or so) but not usually within +/-.005" unless it is a special type of product and the mold/resin/process systems are specifically designed to produce it. It can be done, at a cost.
That can be done under certain conditions, and is achievable by molders that have advantageous conditions, but it is not usually how these necks would be specified. I would not recommend it unless the closure/neck insert required the tight tolerance. Some closure/neck systems do. But, you will be paying for that level of tolerance either through slower cycle times, limited resin choices, or limited supplier choices. Why pay the price if it is not needed?
I am also curious about the "I" dimension having a 33% lower tolerance than the E. Controlled I's are common for in-the-neck fitments. The target for that is set with the blow pin diameter; but it will move sympathetically with E due to neck shrinkage. What mechanism would allow for I to have a lower tolerance range than E, particularly a 33% lower tolerance?
While those tolerances are achievable under certain conditions, I would want to justify the need for each considering what the closure and neck insert actually require. Then I would look and see if I could find another system to solve those problems that would allow more standard manufacturing blow tolerances.
We saw these types of problems with tamper bands designed for injected PET bottles being adopted onto extruded HDPE bottles. That is why closure manufacturers at the time designed closures with tamper bands that would work with the larger variances in A that were experienced with extruded HDPE necks.
I suspect if a salesperson shows up with that spec for a quote; it would be charged accordingly.
Lonnie Jaycox CPP, CDGP
Saint Louis, MO
lonnie@jaycoxconsulting.com------------------------------
Sent: 06-28-2019 10:54
Subject: Extrusion Blow Molding Best Practice.
Looking back on my old 1-gallon HDPE bottle thread specs, your +/- .15mm thread tolerances look good. The 1-gallon tolerances specified were +/- .005in. which calculates out to +/-.127mm. That thread profile was for a 38mm finish. A +/- .150mm spec should be within molding capabilities.
Good luck
John Chomistek
Packaging Lecturer/Program Director
Transforming tomorrow's Packaging Engineers today
Phone: 715-232-5399
Email: chomistekj@uwstout.edu
