55 gal drum liner vacuum sealer
  • 1.  55 gal drum liner vacuum sealer
    Posted 03-19-2021 10:23 AM
      |   view attached
    Hello,
    I'm looking for some options for a "mobile" 55 gallon drum liner vacuum sealer machine. We have two separate drumming lines (not adjacent) and the plant would like to be able to move the sealing machine to between both locations. The drum liner is an aluminum material and fits within a 55 gallon drum and the opening is close to 30" in width. I attached some photos from a larger, stationary sealer at a sister plant but this sealer example isn't exactly what the plant is looking for. I did some google searching and found this website:
    https://www.impakcorporation.com/sealers/vacuum_sealers but haven't work with them prior. Anyone have any experience working with IMPAK equipment?
    The plant location is based out Elizabethtown, KY.
    Thanks in advance for any help and suggestions.
    Justin Burke (jdburke@dow.com)
    Justin Burke
    Dow Inc.
    MIDLAND MI
    (989) 636-1218
