Hi Tim,
Companies that use molded EPS cushions usually have high volumes of specific products to package and protect. Molded parts provide predictable performance in shock, vibe, and compression testing, and they direct the load path of shock inputs into the strongest parts of a product and away from the weakest part of the geometry. Molded pulp can provide all of these same attributes, though the parts are more fragile and weaken more readily with repeated impacts and compression load (which is why boxes sometimes need to be more rigid than when EPS is used). The other reason for using molded parts is to speed up assembly lines and the packaging process vs. manually manipulating streams of paper.
In contrast, Ranpak and Storopack provide good void filler in situations where boxes aren't holding the exact same product from one order to the next, or that product volumes are too low to warrant tooling for a molded solution. These void-filler solutions can provide cushioning as well as blocking and bracing, but being manually placed means repeatability and predictability would be less than molded solutions. Also, the cushioning isn't provided specific to the needs of a particular product, meaning the load paths aren't being engineered to direct impacts to the strongest part of a product. Finally, settling can occur more readily in void filler solutions, thus leaving rattle space in the box if not filled fully. If the product is vibration sensitive, then this can lead to problems.
So, going back to your question, it would seem like comparing foam peanuts to bubble wrap to crinkled paper would be a better comparison than to compare those to molded solutions, whether it be molded pulp or molded EPS.
Kevin Howard
Consultant
www.packnomics.com
www.linkedin.com/in/kevin7howard
cell: 360-606-0235
desk: 360-828-8822
Sent: 5/19/2022 8:48:00 AM
Subject: RE: State EPS Bans
Interesting insight Kevin. Have you looked at moving eps to other materials like Ranpak Padpack or Storopack Track paper?
Tim Kretlow CPP
Hunter Engineering
Bridgeton MO
(314) 716-0275
Sent: 05-18-2022 15:16
Subject: State EPS Bans
Interesting find Tim! The Bill is dated April 19, 2021, but the article from EPE describing the bill is dated June 16, 2021, so I wonder if the Bill was amended or was the EPE article simply wrong? It might take a bit more digging.
In helping products move from EPS protective cushioning to molded pulp I found the standard drop tests offered by ASTM, ISTA, FedEx and others to be insufficient. What I did discover is that there was unknown design margin being offered by EPS cushioning that was never fully tested by the standard drop tests, though the real world was testing these packages in this way. As a result, even though first rev molded pulp cushions easily passed shock and vibe tests, and read nearly identical shock transmissibility as their foam counterparts, they'd fail in significant numbers in real world shipping, especially in e-commerce and developing nations. Why? Because no standardized drop test actually tests all drop orientations, nor have more than one sequence of drops, though real shipping does both of these things. On top of that, no standardized drop test attempts to measure the amount of design margin, meaning they don't tell you how much excess protection you might be providing over the go/no-go test levels. The move from EPS to molded pulp made all of these shortcomings crystal clear. It also became clear that the products most easily transferred to molded pulp protection were those with certain bare product attributes as measured in damage boundary testing. Products with critical velocity change of 125"/sec (with 130 or 135"/sec even better) and critical acceleration of 50 G's were far more likely to be successful in transitioning to pulp and not requiring boxes to be made larger than when those same products are packed in molded EPS. Many people think 50 G's is nearly impossible to achieve for their products, but a raw egg has a critical acceleration level of 60 G's, so maybe it's not as tough as some fear.
Kevin Howard
Consultant
www.packnomics.com
cell: 360-606-0235
desk: 360-828-8822
Sent: 5/18/2022 1:39:00 PM
After some digging, I found the bill, SB 5022 - 2021-22 and it only makes reference to packaging peanuts, excluding all other forms of eps protective packaging.
The bill can be found here: https://lawfilesext.leg.wa.gov/biennium/2021-22/Pdf/Bills/Senate%20Passed%20Legislature/5022-S2.PL.pdf?q=20220518102948
Tim Kretlow CPP
Hunter Engineering
Bridgeton MO
(314) 716-0275
Sent: 05-17-2022 22:20
Washington State will ban protective EPS starting next month
https://epe.global/2021/06/16/laws-to-ban-eps-are-coming-are-you-ready/
California is contemplating similar legislation.
Beyond legislation, consumers clearly prefer curbside recyclable paper based cushioning vs non-recyclable EPS. Molded pulp cushioning can often replace EPS cushions, though it's not unusual to need a stronger box to support edges and corners that are no longer filled in as well as EPS provides. The combo of (possibly) heavier pulp cushioning and heavier (more expensive) box means more weight overall.
Sent: 5/16/2022 9:30:00 AM
Hi Stephen, referring to protective packaging eps. Sorry, should have clarified that.
I did notice the packaging peanut and single-use food and carry-out ban and was curious if anyone had info on the worst case scenario restriction on protective packaging eps domestically or internationally.
Tim
Tim Kretlow CPP
Hunter Engineering
Bridgeton MO
(314) 716-0275
