Cost, transit time and destination are key elements in this decision process. As A Wespetal suggested, the value of the payload is a major driver. Is this one of kind? Iis it a seven figure life saving pharmaceutical? Is it a closed loop between two or more destinations within your supply chain? Is you packaging designed as a returnable, multi-use container?
There are a number of details that need to be clearly defined before a vendor can assist in your decision process. To learn more about the breadth of choices contact me, or any of the contributors so far to discuss your application. To learn more about my products visit
www.pharmatuff.com.------------------------------
Ray Pidock
Director, Temperature Solutions
EFP Corporation
Reynoldsburg OH
(614) 866-0188
rpidock@efpcorp.com------------------------------
Sent: 03-26-2020 15:32
Subject: When to use Passive/Active Thermal Packaging?
Hello, I have a question for any pharma, medical, or food packaging engineers that encounter high value product that needs thermal protection in distribution.
Based on product susceptibility to temperature (shipping & storage specification temp range is given), how do you decide when to use 1) passive protection like foam insulation or gel packs, 2) active thermal protection, or 3) thermal protection?
K. Nori
