  • 1.  Products in bags, diapers, stablizing pallet
    Posted 01-16-2020 01:52 AM
    Hi, My name is Wilsen Kannan,
    I would like check on packing diapers into bulk bags, basically diapers are soft, what sort of bags are meant to pack diapers and is it possible to not wrap bottom of the pallets with stretch film.
    Basically to obtain a stable pallet for transportation and warehousing. Is glue a solution to this type of packaging
  • 2.  RE: Products in bags, diapers, stablizing pallet
    Posted 01-17-2020 11:19 AM
    Hello Wilsen,  Many companies use glue for pallet stabilizers to reduce film, I am familiar with HB Fuller TDS 9255 LP used with the Graco InvisiPac system.
    Diane Kaye | Sales Development Manager, Packaging
    p: 612 206-0353 | dkaye@graco.com
    Diane Kaye
    Graco
    Minneapolis MN
    (612) 206-0353
  • 3.  RE: Products in bags, diapers, stablizing pallet
    Posted 01-18-2020 09:52 AM
    Hello Wilsen. I not sure if it would apply to your particular situation, but there are anti-slip sheets that may help stabilize a pallet load and reduce the amount of stretch wrap required.
    http://www.sdipackaging.com/store/categories.php?CategoryID=2
    Brian Ashinger
    Pipeline Packaging
    Cincinnati OH
    (513) 748-9936
  • 4.  RE: Products in bags, diapers, stablizing pallet
    Posted 01-20-2020 01:58 PM
      |   view attached
    Hello Wilsen,
    We have worked on a few projects, and here is one that we did with Napkins for stacking in warehouse.  We did this by adding an exoskeleton to the product.
    Corey Nugent
    Engineer, New Business Development
    Laminations, Great Northern Corp
    Appleton WI
    (920) 740-6143
  • 5.  RE: Products in bags, diapers, stablizing pallet
    Posted 01-21-2020 07:25 AM
    Load-Loc is another solution on the market.  From Signode.  However,  I am not sure the weight of the load is enough to keep it on the pallet without get 3-4" of the pallet with stretch film.  Test some loads.
    Michael Guarino Sr.
    HP Hood
    Winchester VA
    (540) 247-8985
