Ames 55212 and 56212 are hand held paper style micrometers. I use these in the field. These are analog devices with jeweled movements that are graduated in 0.0001 increments, or ten-thousandths of an inch precision. The accuracy of this, or any measuring device depends upon calibration, or at least the ability of the device adjustment to measure zero. Depending upon the fineness of your measurements, you may wish to invest in a gauge block that will calibrate your micrometer within the range of measurements that you are taking. For instance, if you are measuring 4mil films, you would want a 4 mil or 0.004" gauge block.
General procedure: Clean the tool by closing it gently on a piece of paper or similar material. Drag the paper through the space between the foot and anvil to remove any residue. After removing the paper, adjust the face dial so the needle is on 0. Condition the sample you are testing in a similar way, to remove dirt, dust etc. Avoid measuring near creases, cuts or wrinkles. Lift the foot of the micrometer off of the anvil by moving the lever with your right thumb. Place the sample to be tested in the throat of the micrometer and release the thumb lever. Take your reading by looking squarely at the dial avoiding parallax. Repeat this process until you have taken several identical or near identical measurements. Compare your observed measurements with the values that you expected. If the values are not close to your expectation repeat the process. The flatness of your sample will have an affect on the accuracy of your measurement. If your samples have a lot of curl, you should be sure that the force of the foot on the sample pushes it flat on the anvil.
Christopher Ritz Fellow, CPP
President
Planet R Creative Services LLC
Columbus OH
(614) 486-0121
Sent: 11-13-2020 10:33
Subject: Thickness Measurement
Hello,
Does anyone have any recommendations for an instrument or procedure that can measure thin material accurately and precisely. Looking for equipment that can take readings to 0.0001 inch. Current instruments we are familiar with only take readings to 0.001 inch.
Thanks you in advance.
Sarah Gagnon CPIT
Waukegan IL
(815) 403-8638
